You will need to make one, the Male connector would only be found on the MAF sensor and it doesn't come off easily, lol.
You could hit a wrecking yard and cut MAF wires out with as much wire as needed, or possible, then solder to your wires, or use butt connectors, same color code so should be easy to match.
There are 4 wire MAF sensors and 6 wire MAF sensors, make sure you get the right one.
And just as a heads up, check where the MAF sensor wires run now.
I was surprised on one vehicle that the MAF sensor wires ran all the way around the engine compartment.
Came out firewall on passenger side and ran to drivers side firewall then to rad support, across lower rad support, up rad support, 1/2 way across passenger inter fender and then back to MAF sensor on Passenger side air box, lol.
Why use 3 feet of wire when you can use 23 feet
