3.0 l duratec
pfrye2007
I was thinking of taking my 3.0 vulcan out and swapping for a 3.0 l duratec, At first I thought how could this swap possibly help me much but a friend kept trying to explain about this engine. so... after long hours of extensive research I have found that it would be an excellent swap and just what I need. 240 hp and 233 lb-ft from this engine in the new escapes stock :shok: which is extremly shocking to me because that is 33 more hp then the sohc 4.0 in the fx4. which is 207 hp and roughly 237-238 lb-ft. which obviously the sohc has 4 more lb-ft but with only a little 3.0 I think this is extremely impressive numbers don't you think? Also the fusion, Milan, and Lincoln Zephyr comes with a duratec 30 engine but with variable valve timing with 221 hp and 205 lb-ft which is still impressive. From my research the my vulcans 5 speed transmission will bolt to these engines, I have a lot more research to do as I am wondering how difficult the wiring, fuel delivery, modifications, etc will be and if too much hassle for my time I guess it isn't worth it :icon_rofl: But I was wondering has anyone else noticed these numbers and even thought of this swap or done it or even tried?? If so what are some modifications to be made? And if not What do some of you guys think about the idea of swapping the 4 valve per cylinder dohc available to be twin turbo charged (http://en.wikipedia.org/wiki/Noble_M400) with 425 bhp and 390 ft-lbf ? :yahoo: :headbang: I say we need to get to work and put this to use lol
that would be mpressive to see you pull that off, but i think a COMPLETE donor car would be in order because the new electronics are far mor advanced for the newer duratechs than they were for the vulcans
I agree, would be an AWESOME swap if you could get a complete donor for it.
Do it!
Find a car that was hit in the back and buy it up.
Thanks guys for the support!!! :headbang: I just thought its a super cool idea, from my research this option was available in a late 90s taurus as well so I will have to go to the junk yard and check for donor cars. Also Hopefully I can come across something a lot newer, its just by the time you buy everything to do it, I might as well do another swap but if I get lucky with a donor car for sure I am doing it, be pretty funny to pull up beside a ricer and have 3.0 emplems on my fenders and tell him I have a really bad vacum leak :icon_rofl::icon_hornsup:
Yeah, the 24V 3.0 was available from about 98 up in the tortoise.
If you go for something around 99 or 2000 I really don't think it will be that much worse than a 2.9 to 4.0 or 5.0/5.8 swap.
i had the same idea about swappintg my lima 2.5 for a duratec 25 lol
the idea u have is pretty good man. my grandma has a 04 tribute with the 3.0 duratec and that thing has balls lol
among other thing you need to research is p.a.t.s. you need to make custom headers, probably custom mounts.
on the plus side you can make a hybrid duratec with a escape heads and 3.0 block it is what the svt contour owners do
true p.a.t.s. gets more and more annoying and I will have to look into that idea, thanks for the info :D
