3.0 flex fuel rebuild?
pvtmikes
My question is does anyone know if I can get more power out of a 2000 3.0 flex fuel motor? If I have to rebuild it thats fine, just want to know what I can do to get more power out of it. Any help would be appreciated.
You should visit the tech Library here they have some good info. I'd start there.
It just depends what your goals are, and how much you're willing to spend. You have a decent start for some power, but it doesn't come cheap. The flex fuel engines have a slightly higher stock compression ratio, and running e-85 can have nice benefits too. Especially for forced induction. As far as specific upgrades go,
IMO, there are 3 stages of engine mods for the 3.0.
Stage 1: ( Simple bolt-ons, fairly inexpensive, will improve throttle response, slight increases in power, and can improve mileage)
underdrive pulleys
a decent cat-back exhaust
electric fan
Air intake kit
*an sct X-cal tuner
Stage 2: (More indepth install requirements, increased cost, work best in conjunction with Stage 1 mods)
porting/polishing heads and intakes
roller rockers
headers
*an sct X-cal tuner
Stage 3 : (Most advanced, will see largest power gains, highest cost, )
Tom Morana products
Forced induction
*an sct X-cal tuner
*The tuner can be done at any stage, but making the tuner the last mod you do will allow the tunes to account for other mods, and therefore have a larger net affect on performance. It also keeps you from spending money on additional tunes if you mod things after purchasing the tuner.
