Tractor Dan
Well i got my hands on a Cherrybomb Glasspack for my Ranger and i'm trying to figure out how to mount it to the existing pipe. I'm using clamps for the simple fact it's able to be moved farther towards the rear of the truck if needed. However the problem i'm running into is the Glasspack i got is 2 in for both the inlet and outlet. I think that my pipe on the ranger is 2 in though i'm not sure. Basically what i need to know is will i need any adapters to make it work? It's not flanged, though if it comes down to it i can take it back to Autozone and exchange it for a flanged one. I stuck it up to the end of my exhaust pipe and once i cut the old muffler off i think i could make it fit into the existing pipe it would just be a tight fit. Then again from what i know of exhaust, tight is good because less chance of leaks.
Recap
What diameter is on my truck?
How to hook the Glasspack into the existing pipe?
Feel free to ask questions if your unsure on what i'm trying to explain. As for going with the Cherrybomb it wasn't my first choice but due to monetary constraints i ended up with it. So in the future i will probably upgrade but it will have to do for now. Any help is greatly appreciated.
Dan
Recap
Dan
