InsaneRedRooster
- May 16, 2012
- Automatic
Hi all, back again with problems. I went out to start the truck today, turned the key from off to run, dash lights came on, radio turned on, fuel pump primed. Turned the key to start it and i got a "click" and then Nothing. All the dash lights went out, radio cut off, etc. etc. the battery is hot, I checked all fuses, I can unhook the battery for 10 minutes to reset the pcm and I get the normal startup symptoms (lights, fuel pump, radio) try to start it and i get the same click and then nothing. Any suggestions?
