beaterranger
- Jan 6, 2012
So cruise is set at 75 on my 91, life is sailing along perfect. Water is good, oil pressure good, no missing or hesitation. Then bump, cruise kicks out...on level interstate
Half a tank of fuel showing, 165 miles into the excursion, fuel filter less than 10k old, mass air cleaned a month ago, IAC less than 3k old along with both temp sensors, egr deleted so that's out, hello curveball. Searched all over the forum but most of the similar cases seem to be accompanied with no start/stalling issue. So here we go with yet another stumbling/falling mystery of the 3.0: Sudden loss of power, no CEL, engine NEVER DIED, held steady idle at 1000 (which to me is higher than the usual warm op IAC idle of 700), starts and holds idle on time every time but pops/sputters the second you try to feather any throttle. Specs: 5spd, 3.0, 370k, new electrics (coolant temp sender, coolant temp switch, air temp sensor, TPS, IAC, ICM, Cap, Rotor, Wires, Plugs). The MAF,MAP,O2,EEC, and fuel pump/regulator have yet to be replaced. I still have several tests to conduct but the disconnect IAC KOER passed, wiggle test on sensors passed, tap test on MAP passed, no glow cat. At idle, smells rich but no black smoke, no fuel in oil. If anyone has a general direction based on the described dilemma, please share your thoughts. With no codes, I'm afraid this could snowball into replacing a lot of otherwise good parts hoping to "accidently" fix the problem.
