JasonJ76
- Nov 14, 2017
- Automatic
O5 3.0 V6 Ranger- initially attempts to start and has a deep roaring like maybe a sucking at the throttle body but it dies immediately. It will continues to try and start afterwards but never totally starts. I had the heads reworked about 6months ago but hadn’t had any problems until now. I did not replace the synchro shaft. I’ve replaced the coil and wires(they are put back in right spot), new fuel filter and fuel pump/sending unit. New IAC and TPS as well. OBD2 shows no codes other than P1000 which I think was just from running the battery low. I have 60PSI at the fuel rail. The check engine lights goes out when cranking and the RPMs go up. Anyone have any ideas? I’ve been a mechanic for the last 20 years. One of first I’ve messed with that doesn’t have a distributor though.
