2wd vs 4wd frame to body
1984RESTOMOD
midwest
3" BODY LIFT
33"
Got a 4x4 frame but found a cab off a 2wd. Are the cab mount location(s) compatible?
As long as the cab configuration is the same, don't go trying to put a supercab on a standard cab frame or vice versa obviously.
Also make sure it has a title.
Yeah, that... there were slight changes here and there between some years like in '89 when the front end changed that changed the front frame horns some, in '95 the radiator mounts changed but that's on the core support...
My '90 was originally a 4x2 but put it on a '89 4x4 frame
