2wd Lift shackles
Beef52751
Eastern Iowa
will 93-97 2wd lift shackles lift my 99 4x4? I thought all of the shackles were the same length, but im just makin sure.
Thanks
Beef
AFAIK, all the shackles are the same. You can get a set of Belltech 6400 shackles for about 2" of lift. They are meant to drop a full size Chevy, but those trucks use an inverted shackle design, so it will lift your truck. They should run you about $40-60 depending where you find them.
