Are these "new" heads or "reworked" heads? If the machine shop was not careful when they reworked the heads, some of the valve stems may be higher or lower.
I have never worked on a 3.0, but looking at this link, it shows them having the Ford pedestal rockers and of course they are not adjustable. If your lash is too tight you can use the backyard method and use a shim under the pedestal.
