2010-12 rear disc brakes
Fleetranger
Forum Member
Ham Radio Operator
Roslyn,Pa
2.3 (4 Cylinder)
My 2011 has a standard cab and a 6' bed. Are there different lengths of rear cables for the longer cab/chassis combos or is it one size fits all? When it's together and work properly about how far should the pedal go down?
I had it state inspected one light and the pb failed. Shop replaced fnt cable (said it was stuck it wasn't) rear cables were rusty which was why the brake light on the dash was not turning off when the pb was released. They sprayed with pb blaster and said keep driving it and it will get better. It did not. Pb pedal goes to the floor and does not hold the truck but pass Pa insp.
I suspect that the driver side cable is stretched or both so just want to get my ducks in a row and order the right parts to do the job. Thinking both cables and couple of couplers. Any other small bits? Will be a little while before I get to it as it's kinda cold out.
Tnx for any sage advice.
Best place to find out what part numbers you need is rockauto. You can use what you find out there to do a web search.
Not always, but most of the time the rear most cables are the same on all the different trucks, the front cable is longer or shorter. As you found out, the ones in the rear are the usual culprits.
Those stupid little mini drums for the parking brake are miserable to work with and don’t hold well. It could be a problem with the cables or those mini drums. IIRC, it’s the intermediate cable that changes for the different wheelbase. Rear cables should be the same with the exception of a possible heavy duty suspension option. I ran into that years ago with my first Ranger, I had factory heavy duty suspension and the normal cables were too short. I have a suspicion though since I haven’t seen anything about that lately that the aftermarket may have just gone with the slightly longer heavy duty option for a standard.
Tnx for your practical input. This truck has 4:10/8.8" diff so I don't know if that puts in the hd category.
No, the axle didn’t determine HD suspension. My 00 with the HD suspension was a 2wd with a 7.5” rear.
sort of.
the implementation of roll stability control required bigger and faster rear brakes.
Actually, rather than going to Rock Auto first, you might well be better off inputting your VIN# into: https://www.ford.com/parts
and getting the ford p/n's and info for the parts in question on your truck. Then go to Rock Auto. As often Rock auto will also supply the equiv Ford p/n. And obviously prices will be more favorable. I can sometimes also input the Ford p/n and find that sometimes Rock Auto actually stocks the OEM Ford part at a considerable discount to what the dealer will ask.
YMMV
Tnx for the reply! I had found some p#s but I wasn't sure if they were the proper ones. This is what I have found so far. AL5Z-2A635-C pass side rear cable. AL5Z-2A635-D driver side rear cable. BRCA-280 connector cable which connects rear cables to cam that applies force the the brake shoes. Require two one for each side. The C and D suffix upgraded from A and B (older versions of the same part). Ford doesn't list the driver side cable anymore as I think it's discontinued. Dorman lists a C661251 intermediate cable (AL5Z2A793A) Ford can't tell what they fit but I'm pretty sure they don't fit a '10-'12 Ranger as advertised.
As an aside I grew up near G'sburg in Sandy Spring. Went to Harvard on the pike, lived in Rockville and Damascus a few decades ago. Obtw would it be a fair assumption to make by your screen name that you might be ham?
