2009 Ranger bed swap (info/expertise/advice welcomed)
tsilva2005
Rhode Island
Hi folks, new to the forum! 2009 Ford Ranger Supercab with the 6ft bed. Was curious as to whether or not a 1993 6ft bed will work on the 2009 frame?
From what I understand 1993-2011 beds are all interchangeable to an extent. Two things I haven't been able to figure out...
One being if the 1993 gen 3 bed will mount directly to the 2009 frame? From what I've read they changed the number of mounting bolts for certain years?
Two being if the 1993 gen bed tail light wiring will plug in to the 2009 harness or if it have to be modified using the old beds wiring?
Any input will be greatly appreciated. Thanks in advance!
Welcome!
Yes, dimensionally the 1993-2011 Ranger beds were the same, relative to the bed length and style.
Will bolt right on, the existing holes in the 1993 bed are the same as the holes on the 2009 bed, but the later has a few (2-4) extra. You'll just use the six 1993 bolt locations to mount it and not worry about the rest.
Doubt the 1993 wiring would be plug-n-play, but the 2009 wiring and tail lights should swap right over to the 1993 bed.
Awesome! Good to know thank you for the feedback.
Just found a decent 1993 bed at my local auto salvage yard. The original bed has finally gave way to the new england salt. Found it was cheaper to replace at the price I can get the used bed than rebuild the orignal. Prices being as they are and all...
Noticed in my searching bed supports for these later model rangers are no where to be found nowadays. Only found 1 rear support available. Ironically, that rear support being the only remaining support not rotted completely away lol
Just picked up the truck not too long ago. Definitely a project truck. Glad forums like these exist. Can't beat hands on knowledge and experiance!
