2007 Red Trailer 4X8 Utility Trailer
The project is still on hold waiting on spindles. Apparently, they are waiting on the fabrication facility in Canada to ship spindles to their warehouse in Indiana.
I do still have two more rims I can paint. I just need to get more paper to mask off the tires. If I don't get to it today, maybe I can find a place that sells newspapers tomorrow after church.
it is a south park reference.
Well, it's too wet to work on the truck since it is in the driveway. It can't decide if it wants to rain, sleet, hail or snow (This would have been an especially good year to have the carport up). And even though it is too cold to paint, I prepped the two remaining wheels for paint.
Push comes to shove, I could fire up the kerosene heaters but that takes a lot of lead time and burns a lot of fuel to do that.
those are fancy tires
Nothing special, just 20x8R10 tires with a load C rating. All the better to not make the trailer an anchor when you leave the pavement since the tires are less likely to sink into the dirt the ultra thin 12" tires that came with the trailer did
The Christmas wrap, that took some time and will cost you extra.
I got notification yesterday that the spindles have been shipped. They are supposed to be here Saturday.
I got the spindles. I'll take a picture of a lift spindle next to a no lift spindle once I get the no lift spindles removed from the suspension arms. I have to finish up with work on the 2019 first.
Ok, now that things have settled down a bit on the 2019, I got the spindles and hubs removed from the trailer. So here are picture of the "old" no lift spindles and the 4" lift version.
The 4 inch lift spindles have been installed and aligned.
And it is holding it's own weight.
While coming up with a plan to modify the fenders to make them fit the new suspension, I noticed that there is a definite droop in the rear section of the deck.
I saw this as a possibility while I was doing the work to install the new suspension. The way the weight is supported is different from the old suspension to the new. Plus I did cut out a section of the C channel that held the suspension in place.
I do believe I have a solution. I had planned to install a slide tray on the rear of the trailer for the middle section of the ramp that is currently pinned in place there. Right now, one has to crawl under the trailer to pull the pins, which has been a good enough for now solution, but not a good long term one. So, I have rough plans made already for that. They will just need to be modified a little to incorporate two 6' long 2"X3"X3/16" angle iron pieces to shore up the frame and provide an anchor point for the rest of the tray. The 6' pieces of angle will bolt to two of the three cross members in the from section and to the three in the rear. I would have them run full length, but there are two angled frame rails that run back from the tongue, further tying the tongue into the frame. It may be possible the bolt the angle iron into those angled pieces, giving yet another attachment point but I need to get under the trailer and take some measurements before I decide to include them or not. The picture with the 6' 6" level will give you an idea how hose angles would span the length of the trailer and from what point. At the rear of the front stake pocket, that is in the picture, is where the middle cross frame sits under the deck. That is also where the rear of the angle braces for the tongue get bolted to the frame.
As far as the fenders, I'm still mulling that all over in my mind. Because of the lift spindles being mounted on an angled suspension arms, the center point has shifted forward by about 2". That will obviously shift weigh off of the tongue, which should not be a problem since the tongue weight in most configurations has been on the heavier side of the recommended 10% - 15% tongue weight anyway. So, I have some latitude there. The fenders will need to be shifted forward by 2" as well. They also need to be lowered and some flat bar stock will need to be welded to the existing bracket to move the fenders out. The bracket will need to be bolted on top of the fender instead of underneath or I will need to cut a notch or a slot in the angle on the back side of the fender to allow the bracket to bolt on from underneath. All this movement will also effect the brush guard steps and the bracket to the rear that helps keep the fender steady and solid. The factory mount on theses trailers are notorious for allowing the fenders to wobble and rattle very badly. To the point of failure in some cases. Thus part of the reason the fenders have the extra bracing. That and I don't want a fender ripped off because I got too close to something hard enough the rip off an unreinforced fender.
But camping season is coming fast. I need to take care of the frame first so I can use the trailer to remove the fiberglass cap and install the roof top tent after I get the bed rack and canvas bed cap installed. I have cross bars made for the trailer so it can hold either one after the chain hoist has been used to lift it off of the truck and be moved out of the way so the cart that is holding the opposite either one can be rolled under the chain hoist so it can be lifted and put on the truck.
I did some some measuring and figuring today after fixing the lift gate on the Escape. I can run the 2X3 angle almost the entire length of the trailer (89"). The catch is that I need to notch the angle where the 2X2 cross frame tube runs across the trailer for the suspension. So, I'll have to order some flat bar stock so I can make a sandwich plate around the tube. And of course, I'll need to move the mounts I have for some of the support legs I have stored underneath. Annoying, but such is life when you're making it up as you go along.
I should add that the measurements were taken with the rear of the trailer jacked up so it has a slight bow up. The steel will be installed with the trailer that way as well to combat any sag that happens from hole slop as the structure settles.
I picked up the angle iron, metal for around the cross tube, and the hardware to fasten it all together and to the bottom of the trailer.
