- Jan 8, 2009
- Automatic
HI!... Well this weekend I decided to do the "BLINKER MOD" on my 2007 RANGER. As you know the newer Rangers only have a turn signal bulb in the front head light assembly. Well this mod turns the corner marker light into a turn signal as well. This mod allowing more visibility of your turn signals to other motorists.
Here's a few pics :
Here is the stock set-up from the factory on the D/S.
The BLACK/YELLOW (black wire with yellow stripe) needs to be cut. Make sure to leave enough wire so that this mod can be reversed if desired.
I used weather tight male/female electrical connectors for a cleaner look plus it would be very easy to return to stock later if I wanted to. The dead end of the wire got a opposite connector, and I simply used another connector to block it off. I then used some shrink tubing to make it water resistant.
Now I took the other end of the wire and tapped it into the PURPLE/GREY (purple wire with grey strip). This would be the bottom wire out of the 3 wires on the turn signal harness with the quick clip facing up.
It should look like this :
This is the finished product after everything was taped back up :
Here's a few pics :
