2004 Ford Ranger Pickup Red RWD Automatic SUPER CAB
MasonDaniel7
5+ Year Member
2004 Ford Ranger Pickup Red RWD Automatic SUPER CAB On Ebay
https://www.ebay.com/itm/234060149764?
The bed has an "Edge" sticker. Looks more like a "Sport" with the white gauges and no tow hooks.
YOU could be the 7th owner of this fine aut-O-MO_bill.
For some reason, the lower front fascia reminds me of the front of the STX trucks. Also, the edge would have had a torsion bar front suspension, if the front of that is coil sprung, its not an edge.
Edit- I think there is a torsion bar visible in one of the pictures where the wheel is turned.
I couldn't tell/see if it had the torsion bars either, but I know My '01 Edge, has black gauges and was told the white ones were from the "Sport" trim. Also no "Edge" bedrails, I'm not sure when those stopped, and no Fender trim on the wheel wells. It does have "honey comb" inserts in the grill. Looks like a hodge podge of different Rangers.
Edge bedrails may have been removed to install the fiberglass cover.
Did the edge com with the larger wheels/tires? looks like it has the regular 2wd tires, like 25" or so, as opposed to the 29" 4wd tires.
As far as I know, the 2wd Edge came with everything for a 4wd except the transfer case and axles for the front. So I would think it came with the same tires that were standard on the 4wd.
Copied from Edmunds.com -
P235/75R15 Tires
15 X 7 In. Wheelsyes
All Terrain Tiresyes
