Sinx53
I am thinking about trading in my 96 Ford Ranger STX and the 06 Town & Country for a 03 Ford F-150 Supercrew. I was just wondering if there are any known problems or problem areas to look at with this vehicle?
On the 5.4l;
Apparently spark-plugs can be a bear, stock are a two piece design that breaks easily and then you have to buy a special tool to remove the piece stuck in the head.
There is a gasket for the cam phazers that has a habit of leaking causing bad idle. I have a truck I bought with that problem. Its a $1700 touch to fix the gasket, or replace the motor- ~34 hours labor plus cost of new motor. After researching I put in thicker weight [15w/40] oil and have been driving it since with no problems.
Richard
The '03's should have the improved heads with more threads than the 97-02 trucks.
Are you talking about PI heads? I thought I read the 5.4 started in '99 and the 4.6 started in '01?
No, the only major change was a few more threads for the spark plugs because of the blow-out problem.
