Delete 2003 4.0 Ranger Parts
rous5972
Franklin, TN
Left over from an engine swap and some other maintenance, etc.:
Parts are all in good used condition with the possible exception of the wiring harness that may need a new connection or two... not sure. Also the CD player is inoperable but by my estimate... likely repairable.
Parts:
Viscous Fan
Power steering pump with mount
Alternator mount
Intake manifold with sensors, etc.
Front driveline
Wiring harness
OEM Thermostat Housing w/ Thermostat
6 - Disc CD Player
4 - OEM AL Alloy Rims
1354 Transfer Case: Used Borg Warner 6c transfer case 13-54-000-037. Electric shift unit off a 2003 Ranger but should work 2000 - 2009 Rangers & Explorers. Also could be slightly modified for manual engaging models from I believe the late 80's to 2000 for Rangers, Explorers, & Bronco II's. The unit worked great when pulled about a week ago! Mileage is unknown.
I am very interested in moving this stuff. Let me know if you are interested in anything. All items are located in Franklin, TN.
Parts:
Viscous Fan
Alternator mount
Front driveline
Wiring harness
6 - Disc CD Player
Hello, you don't happen to have a 4x4 CM? Thanks Ken
