- Jan 13, 2025
- Age
- 63
- Bermuda Run
- State - Country
- NC - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
- Automatic
- Total Lift
- nope
- Total Drop
- nope
- Tire Size
- factory spec...
I will try to be brief... I was looking to replace the rear glass, so I needed to remove the headliner. Did that and in the process removed the dome light. While unscrewing the phillips head screws to pull down the dome light, a lot of black plastic started falling out around the dome light housing. After finally detaching the dome light and pulling it down the two wires came loose from the housing and one of them (couldn't see which one) appeared to arc a couple of times against the sheet metal. It didn't occur to me then, but I think that might have been when I blew a fuse. Anyway, after getting everything removed I go to start the truck, and everything seems to work fine. Then I notice that after pulling out of the garage to move the truck, the airbag light is flashing, the speedometer is at zero (while moving, the other gauges seem fine). Getting curious I start trying some other stuff. The wipers don't work. Not sure what else, but the owner's manual seems a bit vague on what fuse does what relative to what I am looking for. Any help woould be appreciated.
