2002 ex power window relay location
Ranger_5.0
Kalamazoo, MI
anyone know where it is. we've checked every fuse in the thing, and searched everywhere on what relay it is, but have found nothing, any help is GREATLY appreciated.
I just sent you a personal message. Open the PDF and do a search for "C239". This is for a 2001 but I am not aware of any major changes from 2001 to 2002. If anybody knows of any electric diagrams for 2002 ranger please send me a personal message I would love to have it for a project I am working on currently.
The only major difference between a 4dr 2001 and a 2002 Explorer is that they redesigned the entire vehicle for the 2002 model year. The Sports are still the same though until they killed them a couple years ago. I will check around but I don't know off the top of my head.
ok guys, ive found some diagrams and such, there is a "accessory delay relay" but no one can seem to tell me where its at. its the neighbors truck so im not gonna tear into it too much unless i know for sure where its hidden, or if its in the underhood fuse block. thanks for any help
You might try the underhood fuse block. The owners manual should explain what is what in there, at least my F-150's does.
well i did find online where it says it is, position #62 in the fuse box, but there is no #62, it stops at 61. the owners manual doesnt say.
Check your private messages. Open the PDF document page 356, component location views. The bottom item C239 attaches to "Accessory Relay Delay". The relay you are mentioning is attached under the dash. Once you pull the radio out its a black rectangle box on the left hand side. You might have to look under the dash instead of pulling the radio but its located under the driver side near the radio portion, look for a black rectangle box about 5" x 2".
Let me know if you find it or not.
