For Sale 2002 2wd coil spring Roush front sway bar (29mm thickness?)
Isk Stark
The HillBilly
2.3 (4 Cylinder)
Total Drop
5"
I have a never mounted 29mm Roush/4wd front sway bar up for sale. It’s for the coil spring front end.
I can’t use it because I’m lowered so the bar hits the frame under compression. I bought this as a front and rear set from @laser3kw’s for sale posting: https://www.therangerstation.com/forums/index.php?threads/last-chance-sway-bar-kit.196655/
This sale is for the front only. Comes with mounting brackets, bushings and all. I will edit this post later with pics. $50
