2001 ranger 4.0 fuel pump circuit issue
Sq1
5+ Year Member
Raymond NE
I have a 2001 4.0. Truck ran and started fine. Now fuel pump doesn’t seem to be running. I swapped some relays and I tried a jumper on the two relay pins. Hasn’t helped. Is there anywhere I can easily check to ensure the fuel pump is getting voltage or does it require dropping the tank? Or any other ideas? Thanks
Did you check the inertia switch behind the passenger side kick panel to see if it’s tripped?
I did check the inertia switch. It seems to be in the correct position.
