2000 w/live front axles
Mickey Bitsko
Pagosa Springs CO>
live everyday like your gonna die tomorrow
I've looked all over and can't find information on how my 1354e operates to engage/disengage the front axle.I'm assuming the front end turns ALL the time, but I don't know?
This all started with me wanting to put manual hubs in place of what I thought I had [PVH].. so I guess my truck is one of the unlucky or not live axle models [built in june 2000].
Also, are live axles a good or bad thing ?I have looked at the tech articles and it reads you cannot put manual hubs on a live axle..
You'd think at my age I could figure this out...not:dunno:
Well I don't personally know what the PVH hubs look like on those models, but if you pull the wheel off and/or dustcap and see a big nut, you have live axles.
Not necessarily a bad thing, less to go wrong, and they'll never not engage when you need them. Technically a slight mileage penalty, but modern vehicles have come a long ways in terms of drive-line efficiency.
Remove the center cap covering the lugnuts.
If you find a 32mm NUT, you have live axle and that's a GOOD THING. Yes, your front axles turn all the time.
Someone else can better explain the transfer case, shift motor, transfer case clutch, etc. operation.
Thanks for the quick response,
no pvh on this truck, just an axle nut, I guess the only way the the axle gets engaged is when I put the transfer case in 4 hi or lo. Not much information on the topic b/c theres nothing to discuss, you engage the transfer case and you have 4 wheel drive end of story.
I'm used to the mileage so, no big deal.
thanks again..:icon_thumby:
Yup, front 4x4 engagement is handled entirely in the transfer-case.
from personal experience with an earlier truck with a TTB axle the mileage cost of driving with the hubs locked is on the order of 0.5mpg around town and ~0.75mpg out on the highway.
A small enough difference that I will often lock my hubs in late October and only actually unlock them if I am making a highway run in clear weather...
AD
AD
Agreed. I generally lock my hubs the first day we get any snow accumulation and don't undo them again until everyone is scrambling to get their taxes to the post office.
Also, I believe I read somewhere that when you go to the CV shafts instead of the u-joint setup on the TTB trucks that the MPG hit drops to something closer to .2 MPG. Basically you have to drive 50,000 miles a year for it to add up to anything skipping your morning coffee once a month can't cover.
On my 98 I permanently locked my hubs. They are like a bic pen spring, I cut the plastic stops out so they could never catch in the free position. Worth the small mpg loss for the reliability.
