mrm
- Jun 11, 2014
I have a 2000 Ranger regular cab that leaks water on the passenger side during extremely heavy rain events.
I can see the passenger side cowl drain with the passenger door open and it does not appear to be plugged. I flushed this drain using water and a piece of tubing bent to direct the water into the drain. When I flushed the drain no debris came out that I could tell. I can see no debris in the cowl from what I can see of the cowl from the holes at the base of the windshield. When I flushed the drain I did succeed in making water leak into the passenger compartment.
With the glove box door open to where the door hangs straight down using an inspection mirror I can see where water has leaked down the extreme right side of the HVAC box. The HVAC box appears to extend up to the bottom of the cowl where there is a foam seal that seals the box to the cowl. It appears that the leak is originating at this foam seal. I couldn’t see any fasteners to tighten at this seal to maybe eliminate the leak.
Does anyone have any experience with a leak in this area? What was the fix? How is the HVAC box attached to the fresh air intake at the cowl? Thanks for your help and advice.
