2000 ranger 5.0 swap
Once she is running smooth and shifting right im gonna get a shaft made for the rear and keep the shortned stock one as a spare
Bed is on exhaust is done took it for a drive shifts good getting a vss code and rear o2 sensors so next weekend have to wire up the vss in the transfer case it shifts fine just late under wot
And got a new alternator the jy one was junk so she charges now
Wel updates broken 1 2 acculmator spring so trans is back out and pump in the 4406 craped out causing a bearing to fail so ordered rebuild kits for trans and transfer case and a shift kit so if weather holds should be running in a week or so
Well most of the bugs worked out so tomarrow its off to get a drive shaft made the redneck one has to go. Also picked up a dana 30 for free so its back to the sas project.
The dana 30 needs cleaned up and regeared to 4.10s and some chromoly shafts but it will do until i find a good deal on some 60s or a donor truck
