Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
If you turn the torsion bars up to level, a 32x11.50-15, 265/75-16 will fit fine, or a narrow 33" like a 285/75-16 or 33x10.50-15. To fit a wider 33" like the common 33x12.50-15 you will need at least a 3" body lift (about $250 plus install) or a 4" Superlift suspension (about $1800 plus install).
With your aftermarket rims with less backspacing, yes 32x11.50's will fit. On stock rims the fronts will rub on the inside.
Very. If they are on an aftermarket 15x8 rim with 3.75" backspace and you have done a torsion twist. On the stock rims, with a torsion twist, they will rub a little on the inside at full lock but not badly.how posative are you that 32x11.5s would fit
