- May 18, 2008
- 92 & 83 project
- Automatic
Not sure where to post this question(s) (please move if needed....)
On the V8 swap i am having conflicts figuring out the electric fuel pump location. Thought of a different system that will involve 2 micro pumps that will feed the switching valve then the main fuel line to the carb. This set up will involve a 2nd switch in the cab that will be 3 throw, front, N, rear, along with the original front back switch that runs the separator valve (F&B).
my thinking is both switches on front tank should work. the pump switch will hit a relay, then pump. X2 front and back... (see diagram)
thanks
thanks
