JakeMcGuire
- Jun 17, 2013
- Automatic
Hey yall, back with more issues.
Truck is a 01 3.0 automatic 4wd.
First off, my small water leak turned into a super soaker yesterday. After looking around I found it. So I was just going to try moving the house up and putting a new clamp on, but as soon as I moved it the connector broke off. Before I can replace it though, I need to know what it is. Not too handy when it comes to trucks, but hopefully someone can help.
Next problem,
I've got an idle that's rough as hell, but smooths out as I acclerate. Truck doesn't have hardly any power though. I've replaced plugs, wires, coil pack, cleaned the MAF, IAC, and EGR with no luck. Also ran injector cleaner and seafoam through it. Finally got the codes off it, and its showing EGR and cylinder 6 misfire. I know the EGR is opening properly, just not sure if its closing all the way. Now I've heard a bad egr can throw a random misfire code, but would it have that big of an effect on the performance?
I'll upload the pictures in just a second of the first part I'm talking about.
Thanks,
Jake
Next problem,
Thanks,
Jake
