2 piece brake lines??
crawlin91
OTOTM Winner
Solid Axle Swap
Crawlorado
My front driverside stock fitting has two hoses that run into it, the passenger side only has one. I got the 2piece lines from the tech library.
1)HOW DO I ASSEMBLE IT???
this pic shows one the line that ran into the top of the stock fitting hooked to my new lines. There is another line behind the mount that you cant see that also goes into the fitting.
Yeah, they dont work easily. I had to get creative with some fittings to get mine setup.
One line that goes into that side comes from the master, the other line runs to the pass side caliper.
Can't they use a splitter like the older ones...or is that too easy? Sounds like you need to run three flex lines on this system...
