2 inch lift!
1988dangerranger
Loveland CO
So I bought my 2 inch and its here.. and going on on sunday. Coil spacers in front and actually a 3 inch block in the back(fix the sag). I was wondering if im going to have an issue with my pinion angle or pitman arm(or anything else for that matter). Advice appreciated! Thanks.
No need for a new pitman arm it will be fine as should be your pinion angle you dont need to worry about it the blocks should have a little bit of a angle to them to fix you pinion angle.
You will need an alignment to get your camber back to normal.
Sent from my LS670 using Tapatalk
Get a set of concentrix to adjust your alignment. Install them before you take it to get aligned or the shop will rape your wallet for you.
Sent from the road while ignoring traffic
Get 3 degree adj. camber bushings. Stempf part number is EX-3
Post some pics when you get it done, Bro!!!
Ok so I ordered 3deg. adjustable camber bushings for the alignment because brakes plus was trying to F*CK me with a 310 ticket for aligning! So Im using 3deg. bushings. will those work?!
3 degrees maxed out should be about perfect. You will also have to fix your toe.
Have a standard alignment after you install everthing. Shoudlnt be more than $100 for a proper alignment.
The reason I recommend concentrix is they allow the shop to have full adjustment.
So do the stempf ones. That's the only one's we use at the alignment shop I work at.
My apologies I thought concentrix was a part name not brand name.
i couldnt even find the concentrix ones.. i just got standard 3Deg. ones.. will those work?
I ordered them in store from napa.. They were the 3 1/4 deg camber bushings for my BII.
