Uncle Gump
Boomers gotta Boom
TRS Event Staff
⭐Supporting Member
TRS 25th Anniversary
- Sep 17, 2018
- Ottawa
- State - Country
- IL - USA
- Other
- 1986 Bronco II
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Automatic
- Total Lift
- 1 inch
- Tire Size
- 265/75/16
- My credo
- Lead or follow... or just get out of my way
It's been awhile.... but I'll try.
The tach wire between the negative side of the coil and TFI allows current to flow from the 12volt positive side of the coil... through the primary windings in the coil to ground at the TFI. It's hard to see "pulsing" 12v to 0v on that wire... unless you have an oscilloscope. The update rate on a DMM isn't fast enough to show that 12 to zero change... it will typically display a varied voltage which would be half of battery voltage... depending on crank speed.
