There were 2 trannys offered in 90, the dreaded fm146 and the desired m50d. You want the m5od. Go to the tech library to help you id it. An easy way to tell is check your build date on the drivers door. Before 9/89, fm146, after 9/89, m5od.
Thank you, well I know I have the m5od. I really liked it, is there any other transmission I could get, maybe aftermarket? I know I've seen an adapter for the 2.9s to have a 4.0 ltr transmission or something similar
anything that fits a 4.0 will fit a 2.9
try to find another m5od
alright thank you what years would fit mine?
did the m50d's change over the years, in other words?
