2.9 to a 40
bf750
Ky
It is what it is
How hard is it to hook up eds from a 93 to 88
What is/are eds?
If you’re trying to swap a 93 4.0 into an 88 with a 2.9 like I think I’m understanding is what’s going on…
You have a couple options. Splice a bunch of wires or swap the dash and dash harness with the motor.
How comfortable are you with doing electrical?
if me and you were sniffing around a junkyard and found a fully intact 93 ranger...
what would we need to ground/test start and run that engine?
If it’s not complete, I wouldn’t even try other than to maybe spin the starter over. You honestly know a lot more of that stuff than I do. I’m comfortable with wiring, but that’s reading schematics and tracing wires. I’m sure the junkyard start up procedure requires less.
an intact truck.
a 93 requires a jumper wire and a quarter with a decent battery.....and you would have to have your own fuel source to feed the damn thing.
i have a jump tank....several jump tanks actually, which usually is just a gas can with a fuel pump in it.
its just a portable a controlled source.
one fuggin wire and a quarter to jump the starter relay......and vroom.
that is stand alone.
Splice is what I'm doing
