I have a 1992 ford ranger v6 2.9, and I am having issues with it stalling after warming up. I have replaced the ignition coil, fuel pump, fuel pump relay, tfi module, and the pick up coil. Any suggestions??
WOW, I guess them it is a Speed Density that make the problem a little harder. Remember Speed Density uses engine vacum as its way of calcuating the engine processes. give me some time I will look into this
I got you more info it is you Idle air control. I used my auto school database and found a large amount of info, but i cannot copy and paste this is as close as I could get. I will try to get you more info http://www.supermotors.net/registry/media/724437_1
For
