majoestic
- Dec 10, 2008
- Automatic
i had a lean system code for a while i was guessing it was running lean meaning not getting enough fuel so i changed the fuel filter and a new inline fuel pump and im now gwtting code 12 ,13 ,41 which is telling me it cant control low and high rpm and telling me no o2 switch detected and o2 senor circuit idicates system lean i did a 2.8 to a 2.9 swap and i do not have a o2 sensor at all was told the 2.9 FI did not neccesary need one but the truck starts perfect but will not leave the drive way cause soon as i put it in gear (5 speed) and try to move the truck acts like its out of gas and back fires some times out of the throttle body whn ya try to give it more throttle it sounds like it has a sock stuffed in the air intake im confused no idea what is causing the problem Please help my job depends on this truck just bogs down the hotter it gets the worst it runs wont idle please help
