Natedog
I'm looking to get rid of un-needed crap and reduce rotating mass at the same time.
My 87 2.9 used to have AC, but I removed it all and changed the heater box out too. Can I un-bolt the third pulley from the crank shaft? As I recall this has four little bolts and comes right off. What about on the water pump? There is a third now un-used pulley there too, but I recall that this one is spot welded together with the other two on there that are still used. Does it come off or do I need to go to jy and get a non-AC truck water pump pulley?
