Usually you can remove the 1 bolt holding the tube, on the exhaust manifold, and then pull it out of the block, have to wiggle it a bit if it's never been out before, it can be stuck in there pretty tight, but it does come out.
Check it for holes, you will see a ridge on the lower tube that is the "stop" where it hits the hole in the block, so tube is always at the same place, making oil level on the stick valid.
Put some high temp sealant on the tube just below the ridge and reinstall tube.
Only oil vapor should exit the dipstick tube, it is well above the oil level in the pan.
To lessen oil vapor check PCV Valve and "Vent" tube(oil filler neck to air intake), these need to be clean and working to reduce oil vapor blow-by out of dipstick and valve covers
