I have an 88 2.9 5-speed. I just replaced the transmission. Everything worked fine for about a week. I was backing out of the driveway, still in the process of engaging the clutch and it stalled. It hasn't started yet.
The first thing I checked was fuel. Every now and then, but only when cold, the fuel pump wont prime when I first turn on the key. (I deleted the inertia switch last winter, which seemed to help that problem but not entirely fix it
Anyway, back to the problem at hand, I pushed the core in the little valve stem thingy in the line to the injectors, and gas squirted out.
Ok, got fuel.
Then I pulled a plug wire and with the above mentioned method I checked for spark. Nada.
Ok, no spark.
So, several trips to the parts store later and I have:
new cap
new wires
new rotor
new pick-up coil
new module (yes both screws are in)
still no spark.
I have proper voltage at the coil. I obviously don't have a good ground or something somewhere. Is there some sort of safety switch or something that would tell that module not to fire? I'm at a complete loss and have pulled that distributor four times now.
