Wanted 2.9 in or near Connecticut
87RangerXLTct
Connecticut
2.9 V6
Stock
Total Drop
Stock
235/75/r15
Looking for a good used 2.9, or just some rocker arms and rocker shafts. Mine is making valvetrain noise when I take it on the highway.
Seeing if there’s anything close to Connecticut before I rip it apart for rebuild
Thanks
That is supposed to be a common problem with those engines.
Additionally, oiling problems were common, and added to the poor reputation of the North American 2.9. Many poorly maintained or high mileage engines exhibit serious valve train noise. This problem is due to a number of design faults. Valve train oil pressure was entirely dependent upon a supply fed through the two center cam bearings. Even slight bearing wear could cause complete loss of oil pressure to the hydraulic valve lifters, rocker shaft, and rockers. Excessive internal “bleeding” through the half-moon camshaft thrust plate also contributed to this, though this can be remedied by reinstalling the thrust plate in an upside-down position. This condition is sometimes mistaken for ticking fuel injectors. This condition isn’t a cause for alarm unless it does it very loudly or after long freeway trips. If it does have the oil pressure checked, it could be low.
