- Dec 4, 2007
- Age
- 63
- Manual
hello
have an 88 ranger 4wd 2.9 that i drive 130 mile a day. i took it to the car wash and cleaned the engine since its leaking about a quart every 250 miles
after the wash it started right up andi drove it 2 miles/let it sit for about 30 minutes and then it wouldnt start
the engine would crank freely for about 5-10 seconds then would bog down like it was firing out of time or i had the firing order off.
pulled the coil wire and it would crank fine all day long
a friend replaced the ignition module and it fired right up. he then set the timing (turned the distro to chenge module)
running fine.
shut off the engine cleaned up and tried to restart the engine.
Same problem!!!
believing i got a bad module we replaced that and it fired up fine till i shut it off. then it did the same thing agian
checked spark at the coil and plugs were firing eradically
the cap,rotor, and wires are new.
checked the cap and it was dry inside.
what would cause the timing to change or blow a module that quickly????
where is the spout located that i saw mentioned for timing???
could this be a problem with the pickup coil???
any other ideas???????
running fine.
Same problem!!!
