question first, symptoms second:
question: why is my truck dong this?
symptons: first my 87 bronco 2 would kind of jerk while driving on the trail, that lead to stalling and that lead to both fuel pumps not working.
i replaced the fuel filter and the in tank pump with new ones.
then replaced the frame mount pump with a used one from junkyard. its wheezing so i will ask for a replacement. (im sure they are not supposed to wheeze, even if it be's quiet off and on.)
i tried to check fuel pressure at the rail but i think my valve is too deep, didnt have time to adjust it, will do that in the morning.
today i blew out the fuel return vent line to make sure it wasnt clogged. (i actually blew the supply line first) now the return line flows fuel where it didnt before.
so, it idled fine for me for 20 to 30 min. i smiled, its christmas day and i get to drive her. wanted to charge battery a little. so it drove for less than 5 min before starting to sputter. acting low on fuel.
i had repaired the float in the tank so the gauge works, plus i saw the couple of gallons in there. ( i made an access hole in the back so i dont have to pull the tank to see in it.)
problem comes and goes, more so once motor is warm. if i let off gas it will idle fine, but if i give it gas it tries to stall. (but it still wants to stay running)
before posting i did read some, i see to check the fuel pressure regulator and see if it leaks gas. also, i have an analog meter to see if there are any codes to see.
today it was mentioned to me that a bad gas cap can cause similar problems.
i am not a pro, or an amatuer, but i am a ford guy. any help you guys have will be much appreciated.
