DL BOGART
I understand it may not be an advisable move, but since it is possible to bolt in a set of these from a 4.0 onto a 2.9, is it possible to go the other way and use my 2.9 components when swapping in a 4.0? The smaller clutch may have a shorter life span than the larger one, but it may also reduce the load on my weeker '87 trans if the clutch can't hold it. (Up until the clutch goes up in smoke...)The donor truck doesn't have the trans or the starter, or the disc/pressure plate. It also has the electric transfer case which I really don't want to mess with...
