Afternoon all.
Simple question, Export 2.9 in my 88 Ranger, there are 2 "pointers" right (passengers side) just above the crankshaft pulley (damper).
Lower one has a "sight hole" in it, other is a bar with an angle cut at the damper end.
Damper has a 3/16" "notch" cut in it, no other marks or "stuff"
which is which, AND, where would be 10 BTDC ? would this be right or left (when looking from the grill) of the marker (assuming the angle cut bar is TDC) I would also assume that right of the bar would be BTDC as the crank rotates CW (again looking from the grill)
I only have a "basic timing light" (No dials just on/off) and there is NO Tin guage with degree marks.
Even have a spare motor, bars are the same on it as well......
Greg
Greg
