Adhawk
Hope someone can help me, My 1986 2.9L Ranger is running real rough at idle and running extremely rich. A month or so ago it always fired up on the first turn of the key, and now it struggles to start and stay going. Everything I have done so far has made it continue to downslide and progressively get worse.
I pulled the stored codes, reset the Brain and have replaced the ECT sensor, IAC, new battery cables, new vacuum lines and fuel filters. The codes I got were in reference to the ECT, TPS, and EGR. I have tried to get codes again with my test light, but all I receive is a solid light. The fuel pump runs continuously with the key on. I replaced the frame pump couple years ago (with the noisiest one ever), and it has always just primed the system for a couple seconds with the initial turning of the key. I have disconnected the fuel lines at various pionts in the system to check the flow and and see if both pumps work and flow\pumps seem good. I don't have a pressure tester to verify pressure at the shrader on the rail so thats all I haven't checked Fuel wise. I pulled a few plugs the other day, and all that I pulled were black and sooty. I'm pretty sure the EGR is plugged up, as I pulled it off over a year ago and used a drill to clean out all the built up carbon where it bolts to the intake manifold. I un-bolted it again a week or so ago, and it still looked the same as the day I cleaned out that port so that leads me to believe its not recycling into the intake manifold. I pulled the vacuum line on the FPR (Installed new one about two years ago) and there was no gas in it or coming out. I also replaced the Fuel relay and relay harness at that time (They were packed full of corrosion). Anyways, that sort of sums up what I've replaced and the issue at hand - I hope someone has some insight into what I could do or check from here, I'm not quite ready to call the scrapper yet as it still runs and operates but just not very good.
Thanks for any help guys.
