2.9 => 4.0 conversion
truckguy
I have an 86 bronco II and i'm wondering what year explorer engines will fit?
thanks for the help, morgan
Do a search. There are a TON of topics on this.
91 - 94 is a common and easy swap.
are the only things i need are the engine, wiring harness and comp?
you need as much from the donor as you can get. Engine, Harness, axles, transmission, computer...... and some even swap in the dash.
youll also need the under dash wiring, if you dont want to cut and splice. ive opted to swap in the under dash harness as well. all i have to do is repin a few connectors whichll take about 20 minutes. EVTMs are your friends.
