XxrangeradrianxX
Is the 2.8l a good or bad engine to keep I need help whether to keep it in my 83 ranger or not I’ve heard bad things about it but just not sure
Any recommendations on what carb swap to putIf it is in good shape and runs good I wouldn't mess with it.
If it it starts needing emissions stuff and you can't find parts and you don't have to deal with emissions inspections a duraspark conversion and carb swap will keep it going.
IMO the computer controlled carb is the biggest problem for them.
Any suggestions where I can find this carb![]()
2.8L Duraspark Conversion - The Ranger Station
Here’s how you can get rid of that terrible TFI Ignition and replace it with a Duraspark Ignition. Ford 2.8 Duraspark Distributor Ford Duraspark Ignition Module (Note 2 Connectors Not 3) Distributor Cap Adapter GM Vacuum Switch … Continuedwww.therangerstation.com
I would go Motorcraft 1250 with 1.08 venturis.
Basically the same carb as what is on it aside from the computer stuff. Found on stuff right before feedback/TBI/EFI came out, like late 70's/early 80's.
