2.8 vs 2.9 flywheel and clutch
mentalbreakdown00
Ford Technician
Tallahassee, Fl
Need to confirm that the flywheels are the same... also from my readings the clutches are 1/16th" difference and the 2.9 should have slightly more holding power? Lastly are the flywheel bolts into the crank the same in a 2.8 vs 2.9?
It depends upon the year. The 2.8 got a different flywheel and slave cylinder for the TK5 in 85. 83 and up clutch disk and pressure plate are the same as on a 2.9 until '88 (with a tk5).
