- Jan 18, 2015
- Automatic
I have an 85 Bronco II with the 2.8 that I used to drive in high school (10 years ago) until one of my heads cracked, I parked it and finally have the time and funds to resurrect him. Got the engine pulled and everything going smooth, down to the bare block. Read the tech info on here for the duraspark conversion and all that seems to make sense. Where I'm hung up is the Carb. The way I understand it you bolt a non feedback carb on top of the factory spacer with the opening coming out the front, held on by those bolts with allen wrench heads, and then seal off that front opening with a piece of metal. Would that seal? Does air flow correctly with an empty space up there? Another option I think I understand is bolting a carb on top of an aftermarket spacer (a felpro, don't remember the number) with the carb bolts not going through the spacer. I'm having trouble wrapping my head around that. Does the spacer just float there and pinched down by the carb? also there's that rectangle hole in front of the circular carb openings normally covered by the factory spacer, what plugs that? Ideally I would like an intake with just a regular two barrel carb hole for me and I could put spacers to get it the height for my throttle cable. Does anyone know if there is an intake like that, off a pinto or something. I know there is the 4 barrel, but 500 bucks seems like a lot, and its 171 cubes, how thirsty can it get. My second choice would be an adaptor that covers the rectangle hole and gets me to the right height. Any help would be great.
