1989
ok so id like to rebuild my stock (and VERY WORN OUT) 2.8 in my 84 ranger but i cant find a decent price on a rebuild kit i would like to do a better cam and machine the head etc. any referances on a place to go threw ?
If the 2.8 is still running good but just blows smoke you can try changing the valve guide seals. You dont need to pull the heads just put the piston on TDC and pressureize the cylinder with air pressure to hold the valves up, Get a palm spring compressor and pop the springs off being real careful not to drop a keeper. I did mine three years now and it solved the excess blowby and the puff of black smoke when you start it. I replaced the intake manifold gasket and it no longer leaks oil out the upper end anymore but am pissed I didnt replace the rear main seal when the tranny was out. She is still running strong tho I guestimate around 300,000 its hard to be accurate it is a bone yard swap 8 years ago.I am in the process of gathering parts for a 2.8 rebuild. I have been able to find most of what I need on E-bay but I am not in a hurry.
My current Ranger has a pretty sick 2.8, has the blow by and smokes when it starts. But it sounds solid and actually runs fairly good for as bad as it is.
It has the Dura-Spark conversion and a 1.08 Ford 2 barrel. Gets 20-22 mpg around town with the AC on and I don't drive for mileage. I could put a 4 liter or a V8 or anything else that would fit between the frame rails, but the 2.8 does what I need. When the carb is set up right it will perform fine. Cold starts in 30 degree weather are fine, as is the hot weather driving. I don't have any problems with over heating and I live in Arizona, where the temp is over 100' degrees daily.
The plan for the 2.8 rebuild is, Mustang II heads with 2.9 valve's Raise the compression to 9.5 to 1 and the usually bore and rebuild. The heads are almost done. If you would like send me a PM and I will send you photo's.
Just duraspark the 2.8 and rebuild it. Its eaiser then trying to switch to EFI.The 2.8 looks real basic to pull out and over haul. I know there's more power to be had with the 4.0 but when I put my eyes on the 4.0 I get afraid.that motor has hoses running everywhere
