2.8 performance
billm85
eckerman,MI
im looking for a place to buy some build up parts such as cams lifters intakes intake upgrades and basically i want to build up my 2.8 maybe even some flattop forged pistons too any help would be great
Theres a few links in the tech library, but not many. i got a friend who has the 2.8 in his 84 b2, and its cammed out the you know what. he said crane cams makes cams for it, but i think if youre gonna go with any performance upgrade my money is on boneyard boost. get some turbo parts from the junkyard and have a fab shop make you a turbo manifold. whole lot cheaper and quicker than finding a turbo kit specifically for the 2.8
Always thought it would be fun to build up a 2.8L. Should check out Sven Pruett's "How to Build and Modify Ford 60 Degree V6s" - the book is based on the 2.8L, but covers the 2.9L and early 4.0Ls as well.
Not sure if forged pistons would be worth while unless you had some sort of power adder. I believe the 2.8L already has flat tops, but cast.
First thing you might consider is getting it running good on a Duraspark setup, once you have a solid platform in that aspect as far as ignition and fuel delivery, then getting it going good with the internal modifications will make things a little more simplistic.
A lot of parts you'll find are not made, but there are manufacturers that will custom make parts. Just remember that you're going into territory with an engine that's getting pretty old and parts are getting harder to come by, not like a 4.0L or 5.0L where the aftermarket is more plentiful and less expensive.
Cam all depends on what you have planned and what you'll use the truck for. I would ask the manufacturer what will work best for your application, or work with them on specs if going with a custom grind.
Pete
