LilBlueTruck
- Feb 24, 2008
I have a 2000 2.5L 4x2 with a 5-speed. Since last spring, when letting off of the throttle, the truck would idle erratically. For example, when putting the truck into neutral at a stop-sign, the throttle would surge up to 2,000 - 3,000 rpms for several seconds before dropping back down to the normal 800. When letting of the throttle in gear, you can feel the truck continue to move forwards, not slowing as much as expected. This problem has been continuing for some time, but it is not consistent. Back in June, I took a trip to PA (nearly 600 miles round-trip) and I was worried that the problem would be an annoyance the whole way; it ran fine with no throttle surge when getting off of the highway or driving around town. It seems to be more of an issue during local driving. I did unplug the IAC back awhile ago to see what happens and, after the engine heated up, it ran smoothly with it unplugged. This would suggest to me that the IAC is causing the surging, but what is causing it to react this way? About a year ago, I did a lot of work to the truck including new timing-belt / cooling system flush / new thermostat / housing with temp-sensors / hoses / O2 sensors / IAC / TPS / plugs / serp-belt. I tried searching the forums here and noticed somebody writing about the DPFE sensor. I figure that I should get a little more input before I spend money replacing parts. There has been no "Check Engine" light, by the way. Any help will be appreciated. Thank you.
